Author: Subject: best/cheapest place to buy SS crush tubes
DIY Si
posted on 7/11/09 at 09:04 PM Reply With Quote
Evening all,
Just a quick one. Where's the best place to buy SS crush tubes to suit an MK Indy? It appears that there isn't a standard size tube available and that I will have to get some modified/made to suit the 3/4" OD and 1/2" ID. Who can do this the cheapest and quickest? I appreciate the two may not be the same!
Sun Tzu, The Art of War
posted on 7/11/09 at 09:26 PM Reply With Quote
Have you tried MK themselves?
IIRC they're just bits of stock tube cut on a band saw (mine certainly weren't turned items).
wilkingj
posted on 8/11/09 at 09:57 AM Reply With Quote
If you make them use a Cobalt drill and a Lathe.
Best Regards
Geoff
http://www.v8viento.co.uk
DIY Si
posted on 8/11/09 at 12:15 PM Reply With Quote
The ones on my car are from MK and they're mild steel, as I thought they still are. I'll give them a try on Monday though.
posted on 9/11/09 at 10:51 AM Reply With Quote
Sorry - you're right the MK supplied ones are/were mild steel.
Are you looking to replace these with stainless ones then?
DIY Si
posted on 9/11/09 at 03:36 PM Reply With Quote
Yup. Having mild steel ones may have helped contribute to my recent wishbones problems, and since I'm replacing the bones, I may as well do it all properly!
posted on 9/11/09 at 07:56 PM Reply With Quote
Suspect that some of the wishbone failures reported on the site may be due to the crush tubes being too short.
DIY Si
posted on 10/11/09 at 04:30 PM Reply With Quote
That and that I didn't realise how corroded they were is, I think, a good part of why the bone failed the way it did.
