New Topic New Reply
Author: Subject: Width of Steel Tubing
Louis M
posted on 9/4/04 at 06:02 PM Reply With Quote
I plan on building my car in stages:
1) summer/fall would be building a locost with stock mustang everything
2) next summer/fall would be upgrading
anyway, i plan on building with stage two in mind, so i will probably not be using stock 1.0" rhs...
what are the tolerances of each type of steel tubing?
1"?
1.25"?
1.5"?
Also, I believe that if I will be using 1.5" tubing, then it will be able to handle at least 450rwhp
James
posted on 9/4/04 at 06:14 PM Reply With Quote
Hicost has run his 430BHP car for 5/6 years without a problem. The chassis is 1" box section.
If you want to increase the torsional stiffness of the chassis then search for Cymtriks' plans- they've been posted a few times. They double the stiffness with a weight decrease.
HTH,
James
Louis M
posted on 12/4/04 at 05:59 PM Reply With Quote
assuming identical plans, wouldn't one w/ 2" piping handles so much better than one w/ 1" piping though? its not much more, and worth it
posted on 12/4/04 at 08:46 PM Reply With Quote
to be frank, no. 2 inch tube weighs twice as much, surely an extra 75ish kgs isnt going to help handling. Plus, as james says, cymtrik's mods are a simple way to strengthen the chassis and it weighs LESS then the book version. Its like compairing brains over brawn.
Louis M
posted on 13/4/04 at 01:17 AM Reply With Quote
thanks
New Topic New Reply
