Author: Subject: Wheel help
sprouts-car
posted on 10/11/09 at 11:43 AM Reply With Quote
Wheel help
Where can i find wheels with less offset??
My problem is this:
Currently I have a really big spacer, and the wheels only just clear parts of the the car. Even with the extra long studs there isnt enough thread sticking out to get the nut fully on (it holds the wheel, but nothing more than that ie not safely). So the only solutuion i can see is wheels with less offset, but where to get these?
Oh a i have tried the wheels on backwards looks ridiculous.
Hope this explains all:
wheel problem
wheel problem
dinosaurjuice
posted on 10/11/09 at 11:47 AM Reply With Quote
if there ford wheels the offset is probably 38mm or there abouts. peugeot or citroen in 108mm pcd is about 15mm offset i think - worth a look anyway.
NeilP
posted on 10/11/09 at 11:48 AM Reply With Quote
Some manufacturers will make wheels with lower offsets - my rears were team dynamics pro race 1.2 on a 0mm offset ordered specially thru wheelmania (they're made in the midlands somewhere IIRC) - You'll need to call a few people as these differing offsets are not often listed in the mags and on the net...
HTH
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
bmseven
posted on 10/11/09 at 12:19 PM Reply With Quote
Careful with Citroen rims as the centre bore is larger so you will need hub rings.
What wheels do you have?
BMW 7 Resource
Bures Pit anyone?
sprouts-car
posted on 10/11/09 at 12:31 PM Reply With Quote
Currently ford sierra ones.
Peugeot sounds like an interesting line of thought, will have to have a look at that.
blakep82
posted on 10/11/09 at 12:37 PM Reply With Quote
mmm deep dish alloys
________________________
posted on 10/11/09 at 12:53 PM Reply With Quote
Mmmmmmmmmmmmmmmm deep dish pizza
sprouts-car
posted on 10/11/09 at 01:05 PM Reply With Quote
Wow, just wow
posted on 10/11/09 at 02:32 PM Reply With Quote
That's never a pizza
Looks distinctly quichey to me
posted on 10/11/09 at 03:46 PM Reply With Quote
Quizza?
clairetoo
posted on 10/11/09 at 08:05 PM Reply With Quote
Quizza?
Its cuz I is blond , innit
Claire xx
Will weld for food......
scoobyhunter
posted on 11/11/09 at 07:19 PM Reply With Quote
xxl studs? or i would say the safer way would be to have your spacers modified so as they are bolted to your hubs(using a countersunk hole so the bolts can be a lot shorter or even using standard bolts) and have allen bolts countersunk sticking outwards so you can bolt your wheels on. if you want some custom made ones i can have them done for you by my freind in germany,he makes ultra high quality stuff and its TUV approved. i use them on my quad,there spun from billet ally,no chineese junk! lol. www.tikt.de
regards,andy
