mads
| posted on 24/11/09 at 11:01 PM |
what ball joints for raceleda uprights?
it's late, i'm on-call and search function is not bringing up what i am after... can someone please tell me what ball joints are used for
the raceleda sierra uprights?
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
Wheels244
| posted on 24/11/09 at 11:22 PM |
If they're the same as mine it's pins into the upright and then rosejoints onto the pins from the wishbones.
GBaggott
| posted on 24/11/09 at 11:44 PM |
Can I ask were you got the pins from? I got some with my kit from MNR but I am after sourcing them for another project on a tight budget.
Cheers Gareth
Wheels244
| posted on 24/11/09 at 11:48 PM |
Hi Gareth
Got mine with the uprights.
I don't think they're that expensive to buy
Rob
mads
| posted on 25/11/09 at 07:18 AM |
Rob, have you got any pics? and it might sound dumb but what do you mean by pins (not come across that term/part before) ?
| posted on 25/11/09 at 08:15 AM |
the raceleda uprights come with a large hole in them, into this you can either put a tapered insert to use normal balljoints, or the aforementioned
pins which basically bolt into the hole and have a protrusion over which to put a rosejoint.
GBaggott
| posted on 25/11/09 at 09:49 AM |
Mads - picture attached hopefully.
Looks like MNR supply the pins -
http://www.mnrltd.co.uk/p_parts_suspension.htm
Cheers Gareth
GBaggott
| posted on 25/11/09 at 09:52 AM |
mads
| posted on 25/11/09 at 09:35 PM |
cheers Gareth - i understand what a pin is now. think i will stick with std ball joints for now. it's the transit ones, right?
