david
posted on 2/12/09 at 11:19 PM |
front mudguard stays.
What is the ideal tube to use for making up the brackets for holding up the mudguards. I hope to make a set that will not break David
Chippy
posted on 2/12/09 at 11:25 PM |
Yes so did I, and they still broke, .
I used 20mm tube and found that it was the flattened section that the actual mudgaurd holding section was welded into that broke, so when I repaired
them I strengthened that part by over welding them, seems to have worked, (so far). Cheers Ray
austin man
posted on 2/12/09 at 11:27 PM |
19mm round tube, I have found that its the flat bar that breaks where the weld id so make sure you use a decent gauge and also make sure it is
inserted deep inside the tube prior to welding
andylancaster3000
posted on 2/12/09 at 11:42 PM |
We avoided using flat material with ours and made them totally from tubular material. It is mostly 3/4" tube and the sections over the wheels
are 5/8" (which slides nicely into 3/4)
They turned out very rigid, pretty light and haven't showed any signs of distress yet. Even after being forced back into shape after being
reversed into heavily at Snett last weekend!
[Edited on 2/12/09 by andylancaster3000]
phil m
posted on 3/12/09 at 07:27 AM |
Version 2 - still going strong after 5 years
Humbug
posted on 3/12/09 at 07:47 AM |
I upgraded from the tube+flat to 1.25" x 0.25" flat bar for the whole stay. Absolutely no probs since then.
Dangle_kt
posted on 3/12/09 at 10:04 AM |
Mine is solid round bar, welded onto 2 inch wide 2mm thick flat. Definatly overkill, but I didn't want them falling off on route to sva!
david
posted on 3/12/09 at 11:34 PM |
wing stays.
Tks lads for your help. David
