aitch
posted on 9/12/09 at 05:30 PM |
sierra rear uprights NOT!
im thinking of using sierra dif and shafts in my mid engined BEC with double wishbone rea suspension and disc brakes
what are the option for buying rear uprights ????
aitch
liam.mccaffrey
posted on 9/12/09 at 05:34 PM |
sierra diff chain driven i'm assuming?
Build Blog
Build Photo Album
aitch
posted on 9/12/09 at 05:55 PM |
yes chain driven i want the flexibility of being able to easily change ratio's as i will probably run some top speed events along side my
busa.
id just sooner buy some proven uprights than try and design my own as i have so much else to design and fabricate
aitch
Myke 2463
posted on 9/12/09 at 06:17 PM |
Several people on the bay selling haynes roadster ones £95 pair ready made or £55 you assemble.
jimmyd
posted on 9/12/09 at 06:22 PM |
And if you go down the route of making Haynes Roadster uprights I believe I have a spare set of the flat plates which wouldn't cost you much,
I'd just need to check the garage. You'll just need the round tubes.
liam.mccaffrey
posted on 9/12/09 at 06:23 PM |
fair point about the ratios. I guess you could use any kit manufacturers rear sierra uprights and possibly wishbones too providing you have
clearance. Usual suspects, MK MNR etc
Also 3GE from here
They sell upright kits and fully welded too.
aitch
posted on 9/12/09 at 06:38 PM |
haynes it is
does anyone have a drawing with dimensions?
thanks aitch
liam.mccaffrey
posted on 9/12/09 at 06:42 PM |
worth it even if you're not building one. the new "the book"
book
[Edited on 9/12/09 by liam.mccaffrey]
Build Blog
Build Photo Album
aitch
posted on 9/12/09 at 06:52 PM |
thanks
book
just placed a bid
aitch
minitici
posted on 9/12/09 at 07:07 PM |
Another possibility is Westfield alloy rear uprights.
Not exactly a locost solution but they are nice.
Westfield Rear Upright render
liam.mccaffrey
posted on 9/12/09 at 07:16 PM |
you can get it brand new in halfords for about 12 quid?? Its author used ot be a member on here. They have a pretty good forum too.
Build Blog
Build Photo Album
fazerruss
posted on 9/12/09 at 07:39 PM |
I made my own based on the Avon geometry but open style design rather than a box design and look nicer IMHO
Forum Code:
rear wishbones
"if assholes could fly this place would be an airport"
aitch
posted on 9/12/09 at 08:03 PM |
Forum Code:
rear wishbones
ooooooooooooo very nice im building a full boddied car so looks not so important just something id rather buy than fabricate
aitch
