Miks15
posted on 19/12/09 at 05:14 PM |
track rod ends
Would anyone have a mondeo track rod end lying around they could measure for me? or happen to know the measurements
I have a Mk2 escort rack (does anyone know the thread size on this aswell whilst im asking?) and E46 hub.
So im after the taper size, and the thread size of the partwhere it attaches onto the steering rack.
Cheers all
Mikkel
RAYLEE29
posted on 19/12/09 at 05:19 PM |
mk2 escort m14x2 rack threads
mondeo ones should fit on there
Ray
Miks15
posted on 19/12/09 at 05:38 PM |
lovely, anyone confirm?
Also anyone know what size the taper is on the mondeo?
theconrodkid
posted on 19/12/09 at 07:23 PM |
http://81.246.78.74/
useful site for that sort of thing
who cares who wins
pass the pork pies
Miks15
posted on 19/12/09 at 07:42 PM |
the mondeo wont work, balls, now gotta find something that will!!
Miks15
posted on 19/12/09 at 07:56 PM |
doesnt look like ill be able to find anything that will work with my current set up
The BMW ones are long so if i can modify them somehow then i wont need any extenders, alternatively if i can find some TRE's with the right
taper but wrong thread then i can get some custom extenders made up to make it work.
Does anyone know what material TRE's are usually made of? is it cast steell? or Mild steel?
One thought is if i can make an adaptor that is M14x2 interal thread, then cut the old TRE off at the right length then weld the adaptor on it might
work, any thoughts?
Mikkel
matt_gsxr
posted on 19/12/09 at 09:24 PM |
Have you considered the RS2000 TRE's?
These fit the Mk2 escort rack but have a taper that is smaller than the standard escort one.
These guys might be able to advise, as they are UK based and manufacture all sorts.
amsteer
It would be nice if you can use a part that is easily replaced and of top quality.
Matt
Miks15
posted on 20/12/09 at 09:44 AM |
i need a taper bigger than the standard escort one unfortunatly
wozsher
posted on 20/12/09 at 10:09 AM |
Could you turn a reducing bush and use the escort TRE
posted on 20/12/09 at 01:53 PM |
Sure you haven't got an Escort Mk1 rack ?
