clairetoo
| posted on 20/12/09 at 03:13 PM |
I've been busy........again !
Can anyone guess what I've been making this week ?
  Subframe jig
[img][/img]
Its cuz I is blond , innit
Claire xx
Will weld for food......
r1_pete
| posted on 20/12/09 at 03:21 PM |
A jig for a bent subframe, have you been out playing in the snow with that Alfa
Danozeman
A metal sculpture for someone for chrimbo?
Dan
mr henderson
| posted on 20/12/09 at 03:24 PM |
A jig for recording the postion of the lower wishbone (aka lower arm) from the front subframe of a car. Probably an older car due to the rack mounting
being in front of the axle rather than behind it.
Hang on a minute, that's a 3,4,5 Cortina front subframe, is it not?
[Edited on 20/12/09 by mr henderson]
| posted on 20/12/09 at 03:31 PM |
not anopther one of those. how many do you have now?!?!?!
clairetoo
| posted on 20/12/09 at 03:44 PM |
Some of you are close
It's a jig I have been making from an Mx5 front subframe - I have been helping to fit a KLDE V6 into one , and a major problem has been
clearance for stuff like the sump and exhausts .
There is a tubular one available in the states which would solve all of the problems , but it's $1095
So I am `on a mission' to build one , and thought it best to build a jig good enough to make more than one
[Edited on 20/12/09 by clairetoo]
Claire xx
hillbillyracer
| posted on 20/12/09 at 04:56 PM |
I did the same thing so I could use the front suspension from a mk1 Golf on my Autograss Mini. Only the mk1 doesnt have a subframe so I cut the whole
front from a rusty one in the scrappy, which got me a few strange looks!
pewe
| posted on 20/12/09 at 05:02 PM |
Boat anchor?
Cheers, Pewe
zilspeed
| posted on 20/12/09 at 06:08 PM |
I've often thought this would be a good idea to replicate pickup points from a FWD hatchback.
That way, the standard suspension complete with wishbones and struts could be used in a Mid engined car with bodywork configured around the suspension
to suit.
For a roadgoing car, not fabricating unique suspension components seems like a good idea.
Don't tell anyone I had this idea though.
gottabedone
| posted on 20/12/09 at 07:34 PM |
This is what they did in the GTM Rossa - complete front end from a metro into the rear - worked very well with a GTI Metro as a donor.
boggle
| posted on 20/12/09 at 07:40 PM |
same in the mg too??
u2u me for details
zilspeed
| posted on 20/12/09 at 08:03 PM |
As long as the right parts were used.
I had a Rossa K3 which used a GTI as the donor.
Before I got it, someone replaced a balljoint and used a non GTI one.
I don't know whether it should be different, but in my case it was and gave it tragic toe out on the OSR.
It could spin in its own length.
Fab car though, and certainly my inspiration for a similar thing in the future.
This was it with the wheel pointing slightly the wrong way.
mr henderson
| posted on 20/12/09 at 08:07 PM |
to suit.
I thought the same, even experimented with it. One problem, though, is the outrageous weight of the standard components, I took a VAG car apart
recently for its bits, I was expecting to use lots of the parts but when I realised how heavy a strut compete with hub, disc and caliper was I slung
them back in the shell to be weighed in and decided to revert to fabricated and bought in aftermarket stuff.
Probably not a problem if the new car is going to be a bit heavy anyway, though.
clairetoo
| posted on 20/12/09 at 09:22 PM |
Some interesting thought there .
The main aim of this is make more space around the engine , with the added bonus that it should be lighter and stiffer than the pressed steel original
Having seen this I saw a lo-cost
alternative being the way forward , with maybe wishbones next on the `to do' list .
Claire xx
omega0684
| posted on 21/12/09 at 09:29 AM |
how about a little prioritisation! i've been waiting for my pulleys for over a blooming month
iank
| posted on 21/12/09 at 10:00 AM |
There's big money being made by people doing tubular subframes for fitting more modern engines to classic mini's. They charge twice the
price of a bare 7 chassis for something with about 1/10th the work/materials.
Decent V6 in an MX5 will make a nice car.
Anonymous
iti_uk
| posted on 25/12/09 at 04:38 PM |
That looks sweet! And wishbones as well... I imagine that would be a sweet kit for someone wanting to, say, make a kit-car using MX5 running gear...
I can't wait to see the results when I get back!!!
Happy xmas from Ireland btw!!! I feel the new year will bring goodness to the car-cobbling world
Chris
clairetoo
| posted on 29/12/09 at 05:44 PM |
Had a couple of busy days !
As soon as the Christmas excess was over (and I could do my jeans up......) I got back in the garage , and got stuck in actually making the new
subframe - there is just the rear mounts and a bit of gusseting on the top mounts to do , but it's 90% done now
  work in progress
  Subframe nearly finished !
Just hope it's not too cold in the garage tomorrow as I hope to have it finished and off the jig !
Claire xx
iti_uk
| posted on 29/12/09 at 07:39 PM |
"Ay, that's alright, that..." - Fred Dibnah MBE (the real master of understatment, RIP)
Chris
[Edited on 29/12/2009 by iti_uk]
prawnabie
| posted on 29/12/09 at 07:47 PM |
Glad to see you finally got the pedal box lid crossed off your list lol
clairetoo
| posted on 29/12/09 at 08:08 PM |
Chris
Just hope it fits
Claire xx
iti_uk
| posted on 30/12/09 at 02:04 AM |
I have faith. What could possibly go wrong?!?...
Chris
pewe
| posted on 1/1/10 at 03:59 PM |
Clairetoo, serious question - what's the advantage of fitting a V6 over let's say supercharging or, if you must, turbo charging a standard
1.8 or 2 ltr engine ?
Logic would say that you can bolt on a supercharger a lot easier than the aggro involved in fitting a different engine.
Or is it the same answer as to why anyone would fit a supercharged Lancia engine into an F27 - because you can and/or because you happen to have the
engine lying about?
Cheers, Pewe
[Edited on 1/1/10 by pewe]
clairetoo
| posted on 3/1/10 at 10:17 PM |
The main reason for going for a V6 rather than turbo or supercharging the original 1.8 is just to have a V6
But also - there is no way a blown small engine will have the flat torque curve of the V6 - mine is happy to pull away at 800 rpm in second gear , and
pull seamlessly to 8000 .
Plus theres always the option of a turbo or two on the V6 - the KL can make up to 800 bhp on twin turbo's , while 600+ is not unusual
link to 800 bhp KL V6
[Edited on 3/1/10 by clairetoo]
Claire xx
Angel Acevedo
| posted on 4/1/10 at 12:04 PM |
Pick up Point Bracket Length.
quote: Originally posted eby clairetoo
As soon as the Christmas excess was over (rand I could do my jeans up......) I got back in the garage , and got stuck in actually making the new
subframie - there is just the rear mounts and a bit of gusseting on the top maounts to do , but it's 90% done now
  work in progress
Clairetoo,
Aren´t the lower front (in thr picture ) pickup brackets a little bit long?
or are you planning on reinforce them in any other way?
As per the V 6 selection, tome, some of the best sounding motors here in Mexico are the 2.8 and 3.1 liter V6 made by Chevrolet (Vauxhall?)
Regards.
AA
