Aled_g
| posted on 21/12/09 at 06:00 PM |
Toe Adjustment
Anybody got any ideas of the best way to adjust the toe on a double wishbone rear suspension on a Locost, rose joints? ball joints?
MK9R
| posted on 21/12/09 at 06:31 PM |
is this a existing car or one you are building now?
RichardK
| posted on 21/12/09 at 07:21 PM |
This is how I set mine up and its been ok as a starter.
LINKY
Rich
Gallery updated 11/01/2011
snapper
| posted on 21/12/09 at 07:48 PM |
You can use washers between the hub carrier and the hub to set the toe, the Lightning Rod oval racers do this to get rid of the camber and add some
toe to make the cars turn in better.
When you get the toe where you want it you can then get the hub carrier milled and dispense with the washers.
I eat to survive
I drink to forget
