adrianreeve
| posted on 23/12/09 at 09:37 PM |
Best grease for wishbone bushes?
Just wondering what the best grease is to use for the crush tubes on the wishbone bushes.
Adrian
Steve G
| posted on 23/12/09 at 09:45 PM |
Did you not get any grease with the bushes at all?? Obviously not superflex ones you have - so poly bushes of some other make??
Polyurethane or PTFE grease is what you need (logical really). Dont use a petrolium based grease at all as it will eventually degrade the poly
bushes
[Edited on 23/12/09 by Steve G]
whitestu
| posted on 23/12/09 at 09:54 PM |
I used silicon grease which didn't really work - they creak like mad!
I've heard of Coppaslip being used to good effect but haven't used it myself.
Stu
spud69
| posted on 24/12/09 at 11:02 AM |
I originally used silicone grease but mine also squeaked like mad. Took them off and re-greased them with copper slip and have been fine since.
| posted on 24/12/09 at 02:53 PM |
Rubber grease from your local motor factors . Make sure you have no issues with the crush tubes being too short before assembly
