locoluego
posted on 30/12/09 at 06:29 PM |
type 9 reverse gear wont select
i have just bought a type 9 out of a 1600 sierra. it didnt have a gear stick but i had one lying around so i have used it. it too is from a type 9 but
to get the bolt hole to line up an the reverse gate on the stick to line up i had to push the stick down and rotate the plastic ball round 180 degrees
so it all lines up! any way i can selet all 5 gears but it wont go into reverse is this normal as its not yet in the car its on the garage floor. you
can push the stick down and it goes across and forward but it dosnt click and engage it sort of hits a dead end half way..... thanks
Tatey
posted on 30/12/09 at 06:31 PM |
I can select all of the gears on my type 9 including reverse, it's not in the car yet. So you could possibly have a problem.
posted on 30/12/09 at 07:18 PM |
Have you tried turning the input shaft while you do it ? It could be the gears are not meshing.
posted on 30/12/09 at 07:20 PM |
Have you got the little plastic saddle that fits over the selector shaft for the gear lever to locate into? Have you tried selecting reverse without
using the gear lever?
skinned knuckles
posted on 30/12/09 at 08:33 PM |
last time i played with a type 9 i had a problem engaging reverse. i will try to explane how i fixed it but have no idea of the technical names for
the parts. There is a little cut away on the gear leaver that you have to move down so that it passes a guard that prevents you from accidently
engaging reverse. this section of the gear box/lever also engages the reverse lights i seem to remember.
there was a bit of crap in the mechanism that prevented the lever from moving down all the way down and as a result the cut away didn't pass the
guard properly and the gear wouldn't engage
bit of crap was found and removed and the whole thing worked fine.
could be worth a go
A man isn't complete until he's married, then he's finished
locoluego
posted on 30/12/09 at 11:48 PM |
thanks for the replys guys i have tried turning the input and output shaft and i have got the plastic saddle but i think there could be a problem may
be with the selector i took the cover off the box and there was a sort of collar that also locates in the cover with this removed i could sort of aid
reverse to select will investigate more tomorrow
locoluego
posted on 31/12/09 at 12:40 AM |
type 9 tech manual
anyone got a strip and rebuild tech manual for a type 9 5 speed they want to sell/lend near newark??
blakep82
posted on 31/12/09 at 12:45 AM |
the lever you had laying about is definitely from a type 9 yeah?
i don't know other boxes, but just thinking if yours was from a type e box, it might be a bit different?
and are you sure the upside down U shape bit on the bottom of the lever has located on the bit inside the box correctly? seem to remember i had a
similar thing with my lever once, but i'd stuck the lever on in the neutral kind of position when the gearbox was in a gear
[Edited on 31/12/09 by blakep82]
________________________
