Author: Subject: Which grease for caliper sliders?
adrianreeve
posted on 4/1/10 at 06:57 AM Reply With Quote
Do I need any special grease for caliper slider pins, or can I just use copperslip / LM / whatever is lying around!?
Adrian
Danozeman
posted on 4/1/10 at 07:18 AM Reply With Quote
Copperslip. or there is proper stuff which i find to be crap so always use copperslip.
Dan
GMPMotorsport
posted on 4/1/10 at 08:27 AM Reply With Quote
Likewise, always use cooperslip and never had a problem.
www.gmpdevelopments.co.uk
www.gmpmotorsport.co.uk
ARDS Instructer.
designer
posted on 4/1/10 at 08:29 AM Reply With Quote
Yes, Copperslip is the only way to go.
posted on 4/1/10 at 10:06 AM Reply With Quote
For the pins I use red rubber grease or cv joint grease.
posted on 4/1/10 at 10:37 AM Reply With Quote
I find Copaslip dries up and sticks worse than before, proper silicone brake grease or rubber grease works better.
Angel Acevedo
posted on 4/1/10 at 12:21 PM Reply With Quote
Waterproof Grease
Silicone grease.
Or Waterproof Grease, I got a sample of Waterproof Grease a few years ago, I don´t know brand, type, or even if there´s such a thing as waterproof, but it works great, I still have some lurking around in my shop that I use now and then on Dayli Drivers.
HTH
MikeR
posted on 4/1/10 at 12:52 PM Reply With Quote
i'm sat here puzzled .... surely all grease is waterproof by its very oily nature.
posted on 4/1/10 at 01:16 PM Reply With Quote
Not really normal greases tend to wash out if expose too water for too long.
Angel Acevedo
posted on 4/1/10 at 02:22 PM Reply With Quote
Yes, I know, but this was supposedly a very special grease for offshore use.
I still keep in touch with the guy that gave it to me, I´ll try to find out Brand and Type and post with TDS.
AA
fesycresy
I wouldn't use copper slip.
CV grease for me.
Bluemoon
posted on 4/1/10 at 04:14 PM Reply With Quote
^^ dito, needs to be rubber safe, other wise the rubber will probably be attacked in time.. Hence silicone grease is o.k, or other rubber grease..
Dan
COREdevelopments
posted on 4/1/10 at 06:14 PM Reply With Quote
like he said above, copper grease tends to swell the rubbers on the slidders and makes it worse than before. I use the red brake grease.
Rob
adrianreeve
posted on 4/1/10 at 07:12 PM Reply With Quote
Thanks for the replies
alistairolsen
posted on 4/1/10 at 10:39 PM Reply With Quote
clear silicon grease
My Build Thread
