bikkel
posted on 19/4/04 at 07:12 PM |
??brakefluid reservoir for dual girling MC's??
WHat kind of reservoir ( preferably with SVA caps) is everybody using for their girling mc's? shpuld fit 2 std rubber brake hoses.
looked at a saab one ; but 18 pounds at a scrappy for a bit of plastic...
thanks
koen de jong
www.zx12r-indy.tk
www.zx12r-indy.tk
highspeeddirt
posted on 19/4/04 at 08:38 PM |
If you have the master cylinders without a reservoir then the plastic resevoirs sold by Merlin Motorsport do the job, but at over £20 for a single
reservoir or £45 + VAT for the twin with SVA cap they are expensive. You also need special hose at £11.70 + VAT per metre! If you have not already got
your M/C's then why not get ones with built in reservoirs and use the Ford caps I posted about earlier.
eddymcclements
posted on 19/4/04 at 10:27 PM |
I got one out of a 5-series BMW at a scrappy. Dual outlets, brake fluid level warning sender, made by ATE. Fiat Tipos also have a triple outlet
reservoir with a fluid level switch (hydraulic clutch on a Tipo, see?). If you're really stuck I have a spare one you can have.
If your scrappy is charging 18 quid for something similar....go somewhere else!
Eddy
bikkel
posted on 20/4/04 at 07:09 PM |
thanks eddy
i'll take a look at the beemers on my scrappie
koen
www.zx12r-indy.tk
Findlay234
posted on 20/4/04 at 07:14 PM |
What type of brake union do you need to go into the MC? 3/16ths or 10mm?
marc n
posted on 22/4/04 at 07:57 AM |
re resevoirs
shameful plug i know, and apologies
have a look at mnrltd.co.uk under brakes
regards
marc
Mave
posted on 22/4/04 at 03:16 PM |
Koen,
I just got this reservoir:
http://home.tiscali.be/andydebecker/images/mastercilinder.jpg
It has two exits, and should be easy to connect to your mastercylinders. This is what I intend to do.
Oh, it comes from an Escort I believe (but I'm sure there are thousands of alternatives (like Sierra).
Groet,
Marcel
