big-vee-twin
| posted on 9/1/10 at 03:15 PM |
Rear Bearing Carriers
Hi All,
What bolts do you guys recommend for the bolting on of the rear Sierra bearing carriers to the uprights, don't have the original bolts
http://www.triangleltd.com
plantman
| posted on 9/1/10 at 03:52 PM |
i used 12.9 socket head bolts from namrick
screwed them in with loctite and then chopped the ends off and used lock nuts
big-vee-twin
| posted on 9/1/10 at 04:26 PM |
12.9
O.K. thanks
| posted on 9/1/10 at 09:06 PM |
Get down the local Ford garage and pick up the correct bolts for about £9 IIRC. 13mm hex head bolts with the right head, shank etc. Drop of
threadlock and the job's done.
