Author: Subject: GearCalc
jrrsparky
posted on 15/1/10 at 08:38 PM Reply With Quote
GearCalc
Can any body confirm that my calculations are correct (or otherwise) as i understand the R1 gearbox has a final drive of 1.58 and have calculated this with the 3.92 ratio of the diff and the result is 6.19
GearCalc v2.0.0.3 Copyright ©2001, Peter Ogden
Gear Ratio, Speed and RPM Calculator
Gear set: Manually entered values
Gear 1 2 3 4 5 6 Final
Ratios: 2.500 1.842 1.500 1.330 1.200 1.115 6.190
(diff + gear box final drive)
Final = (3.92 x 1.58)
RPM @Peak Power: 10500 Tyre Size: 205/50 x 15
Tyre Diameter: 23.07 in
Tyre Circumference: 72.48 in
Gear Mph per 1000 RPM Mph @10500 RPM Mph @11500 RPM
1 4.44 47 51
2 6.02 63 69
3 7.39 78 85
4 8.34 88 96
5 9.24 97 106
6 9.94 104 114
[Edited on 17/1/10 by jrrsparky]
daniel mason
posted on 15/1/10 at 10:33 PM Reply With Quote
i run 205/50/15" toyo r888's on my mnr. 2001 carbed R1 motor(133 BHP at wheels) 3.62 lsd and i can hit 123 MPH on limiter in 6th
adithorp
posted on 16/1/10 at 10:07 AM Reply With Quote
First... Welcome to the mad-house!
Second... it all depends on which R1 motor you have as the final drives (and gear ratios?) are different from one to another.
There's a gear calculator here...
http://www.locostbuilders.co.uk/viewthread.php?tid=121319
...but it doesn't have all the R1's listed.,
adrian
http://jpsc.org.uk/forum/
jrrsparky
posted on 16/1/10 at 04:13 PM Reply With Quote
Thanks for your help
daniel mason
GearCalc seems to be very accurate as it had a top speed of 124 MPH for my 93 R1
adithorp
Thanks for the link it has the ratios for my engine already entered and confirms the final drive ratio as 1.58
