prawnabie
| posted on 18/1/10 at 09:02 PM |
Rear wheel cylinder sizes
I am using a transit master cylinder with a 23.81mm bore. Cortina calipers up front with standard MK2 drums (8" .
Will I see any benefit from going from a 20.6mm wheel cylinder to a lower size such as 19 or 17.6?
I don't have a problem, Im just replacing the brakes and wondered if there will be too much braking on the back with a smaller bore cylinder
CHeers
Shaun
daviep
| posted on 18/1/10 at 09:19 PM |
You'll have less braking on the rear if you reduce the size of the wheel cylinder. F = PxA
Davie
prawnabie
| posted on 18/1/10 at 09:26 PM |
Top man thanks
