subk2002
posted on 22/4/04 at 09:18 PM |
Diff oil ????
Im going to replace the oil in my diff.
Is CRX LS 80w90 gear oil (semi synthetic) suitable for a sierra 4x4 lsd mounted to an R1 engine??
Cheers Drew
givemethebighammer
posted on 23/4/04 at 03:41 PM |
I have used:
Castrol Differential EPX 80W-90
SAE 80W-90, API, GL5
and for the my type 9 gearbox:
Castrol Manual EP80W
SAE 80W, API, GL4, MIL-L-2105, MB235.1, ZF TE-ML02
both from Halfords, general consensus on the Westfield forum was these were exactly what was required. Think the GL bit is as important as the SAE
rating.
GL4 for the gearbox and GL5 for the diff and the two don't mix
Mk-Ninja
posted on 23/4/04 at 04:16 PM |
Just out of interest my local garage recommend to put automatic transmission fluid in gearboxes these days, they recon they were advised to do this by
ford, aparently it sorts out several gearbox related problems. They DIDNT recomend it for the dif though.
Would apreciate any comments.
I'm sure I've got one, just don't know where I've put it
subk2002
posted on 23/4/04 at 05:05 PM |
So would the stuff iv got do the job? i heard you need a special oil for a sierra lsd .
Drew
subk2002
posted on 24/4/04 at 10:36 PM |
So has no one changed the oil in there diff ???
posted on 24/4/04 at 11:19 PM |
That stuff is like p!ss compared to EP80 that is used in type 9 box. They probably use it in newer front wheel drive boxes with the diff incorporated,
but I haven't heard of it. Type 9 has no lubrication problems with EP80 anyway so why risk it.
