prelude1980
| posted on 24/1/10 at 07:06 PM |
Sierra 4x4 Diff
just a quick question, is the diff flange the same from a 4x4 rear diff as to a non lsd push in shaft diff.
Forgot to add i mean the propshaft flange
[Edited on 24/1/10 by prelude1980]
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
Mr G
| posted on 24/1/10 at 07:41 PM |
yes
prelude1980
| posted on 24/1/10 at 07:42 PM |
brilliant i wasn't sure i want to upgrade from a none lsd with drums to a lsd with discs
gets you.
Mr G
| posted on 24/1/10 at 07:55 PM |
As long as you swap it over with one the same size i.e 7" for 7", incase you got hold of a 7.5" without realising. Unless your diff
mounting width is 7.5 anyway and your using spacers (not clued up on tiger rear end)
G
prelude1980
| posted on 24/1/10 at 07:56 PM |
oh that's a good one didn't think of that. there aren't any spacers
gets you.
Mr G
| posted on 24/1/10 at 08:05 PM |
Can't think why it shouldn't be a 7" already in there then but i'd say measure up just incase as you know how sods law works,
you can cut a 7.5" down to get then in the space for a 7" if that's what become available but a straight swap for the same size is
obviously the easiest route.
mcerd1
| posted on 24/1/10 at 08:51 PM |
before you start thinking about the 7.5" cossie diffs
the sierra 2wd cossie ones have larger flanges for the driveshafts - only the granada cossie's have a 7.5" diff with the same size
driveshaft flanges as a 7"
at least its easy to tell the difference between the 7" and 7.5" diff's - the 7" one have 2 long bolts right through them and
2 short ones into threaded holes
the 7.5" have 6 short bolts into threaded holes
[Edited on 24/1/10 by mcerd1]
