Author: Subject: Sylva Riot
dan8400
posted on 1/2/10 at 02:47 PM Reply With Quote
Sylva Riot
Hi, had a look at one of these and quite like them. One question is... if i build a R1 powered version do i need reverse for IVA and how is this mounted? Quite a small car.
Just wondered if anyone is building one on here
Dan
posted on 1/2/10 at 02:52 PM Reply With Quote
I can help with the first bit Dan... Yes - you will need a reverse for IVA.
It's Evolution Baby!
dan8400
posted on 1/2/10 at 02:58 PM Reply With Quote
Ok thanks. Answers the first part
Not sure about reverse. Uses chain drive onto a fiesta diff with a sprocket bolted to it and the R1 sprocket on the gearbox. Don't see how you would connect reverse or where there would be any room....
Can anyone else help?
Don't really want to build the CEC version.. i fancy a dabble into the BEC world
Dan
Bluemoon
posted on 1/2/10 at 03:03 PM Reply With Quote
Don't know I would guess a gear on the diff, to a starter motor, you would only engage motor in neutral!
Dan
MK9R
posted on 1/2/10 at 03:04 PM Reply With Quote
you can fit a reverse, Andy raced his in RGB last year and you have to have a reverse fitted.
http://www.pistonheads.co.uk/sales/1281635.htm
Tim Hoverd is build a J15 which is basically a riot chassis and he has a plan for a reverse.
http://www.hoverd.org/Tim/
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
stevebubs
posted on 1/2/10 at 03:46 PM Reply With Quote
There's a few people who will be able to help answer your questions on the sylva-chat list on googlegroups...
PAUL FISHER
posted on 1/2/10 at 03:54 PM Reply With Quote
Dan,have you had a look at the MK Midi,a cheaper option than the Riot,there's a few people on here building them now
http://www.locostbuilders.co.uk/viewthread.php?tid=129170
zilspeed
posted on 1/2/10 at 05:35 PM Reply With Quote
It troubles me to say this, because I've never said a bad word about a Sylva in my life and I have the greatest of repective for MK's designs and workmanship.
However.
Much as I like the concept of both the Riot and the MK Midi, (they both move the game on to a level relevant to the current donor stock out there, which is no longer the Ford Sierra) there are things about both of them which I really can't get on with.
In both cars, if you look at the rear of the chassis in plan, (not elevation) the engine compartment is basically a big open box with sod all traingulation apart from a small amount on the bottom plane.
The top of both chassis is a big open space with nothing going on.
Don't want to pi5h on anybody's bonfire, but that aspect of both cars, I really don't like.
It's relatively simple to build independent triangulated structures at either side of the engine bay which both closely fit around the engine and carry the suspension. There are loads of respected racing car designs out there with very similar structures and not by mistake I would suggest.
Still fine cars, both of them, and I would have one in a moment, but just being honest, I don't like that aspect of both cars.
ashg
posted on 1/2/10 at 05:52 PM Reply With Quote
when i went up with toltec to collect his riot chassis the finished r1 car that they had there used a starter motor reverse mechanism.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
dan8400
posted on 1/2/10 at 06:29 PM Reply With Quote
Ok so it is possible. I haven't driven one but have seen one and Jeremy seems to know his apples. Nice fella too. I'm half way through zetec upgrade on my supercat (with help from ashg by the way ) but after that i may be looking into a Riot or a single seater of some sort.
Decisions decisions!!
At least i know a riot will reverse now. Thanks everyone
Dan
Steve Hignett
posted on 1/2/10 at 09:29 PM Reply With Quote
I think Martin (MK Engineering) has already sorted the reverse aspects for the MK Midi, so not a bad place to start looking
