mangogrooveworkshop
posted on 25/4/04 at 09:11 AM |
MK de-dion indy ball joints
question
What are the ball joints (top and bottom) on the MK Dedeion indy. The young pup was a little hard on them and has stuffed the rubbers taking them
apart for painting.
I know the track rod ends a fraud Sierra and the uprights are Sierra with an
adapter.
thanks in advance
posted on 25/4/04 at 11:54 AM |
Transit drag link right hand thread top and Maxi bottom joint if they are 2 holes, cortina if 4 holes. It is the front wishbone outer joints you mean
is it ?.
mangogrooveworkshop
posted on 25/4/04 at 05:33 PM |
Front wishbone outer joints top and bottom MK Indy DE deion
this is the bottom one what ID do you put on that
[Edited on 25-4-04 by mangogrooveworkshop]
posted on 25/4/04 at 05:59 PM |
Some use the astra joint on the bottom. If you can find a picture you could compare it with that.
Tblue
posted on 25/4/04 at 06:52 PM |
Rally Design do universal covers out of polyurethane. You could look at the website but as it seems to be low quality renditions of the catalogue
you'ld be better getting a catalogue off them anyway. Page 43, come in a range of colours too.
Mk-Ninja
posted on 25/4/04 at 06:58 PM |
Sorry only just seen this thread.
Im a bit confused as I dont get the dedion bit, the indy was never a dedion.
If it is dedon then it is the early MK.
If its an Indy then all the above is correct, it might be correct for a dedion but not sure. Best give MK a ring.
I'm sure I've got one, just don't know where I've put it
posted on 25/4/04 at 07:27 PM |
It's the front wishbones using Sierra uprights so it doesn't make any difference what rear it is. That's why I didn't bother
remarking on this
timf
posted on 26/4/04 at 07:30 AM |
joint pictured is an astra lower ball joint
mangogrooveworkshop
posted on 26/4/04 at 09:19 AM |
Thanks Guys,
That should help a lot. Yes it is an early indy with the diddyrider back end.
The chassis was bought from mad4x4 `s mates in Montrose back in november. So the history is a bit murky.
Thanks for the Rally design tip I check the cat.
