howard mann
| posted on 15/2/10 at 10:44 AM |
running gear
can any one tell me what size wisebone brackets i need for bushs 36 mm wide. as i have bought a ron champion chassis off ebay. and brackets are 51 mm
wide so there is gaps the bushs are metalastic. can i use metal washers or polyurethane washers. to make tight fit cheers
MK9R
| posted on 15/2/10 at 11:38 AM |
i have rose joints in standard brackets and space them using washers, gives you adjustment to change the geometry
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
James
| posted on 15/2/10 at 02:21 PM |
Get a bunch of stainless washers and use them to sort you suspension geometry. You need 22mm castor so if your wishbones are as per the book (which is
wrong!) then you can use the washers to adjust it!
HTH,
James
- Muhammad Ali
howard mann
| posted on 15/2/10 at 02:38 PM |
thanks for that lads mind at rest now
