Author: Subject: Conversion of Peugeot struts to coilover question
2cv
posted on 19/2/10 at 01:52 PM Reply With Quote
A friend asked me to ask this question for him.
He would like to convert the standard strut to coilover by removing the spring pan and welding on an adjustable spring seat. He says the standard strut cannot be dismantled and here's his question;
Does anyone know of a Peugeot 205 strut with a removable insert so that it can be taken apart whilst the welding is done. Thank you for any help here.
madrallysport
posted on 19/2/10 at 03:20 PM Reply With Quote
the only 205 strut i have ever seen with a removable insert is a fixed platform bilstien, we used to use these on the group n rally car, i stripped one removed the spring platform and weilded a thresded outer on to it to convert it for 2 1/4" adjustable spring.
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
2cv
posted on 19/2/10 at 04:05 PM Reply With Quote
Thank you for that, I'll certainly pass it on to my friend. The trouble is, Billies don't come cheap.
madrallysport
posted on 19/2/10 at 05:17 PM Reply With Quote
Check this link out below you some times see them on it - rally second hand parts link
2cv
posted on 19/2/10 at 07:59 PM Reply With Quote
Thank you very much; really helpful.
MikeCapon
posted on 19/2/10 at 08:21 PM Reply With Quote
There is a way to do this without risking the damper mechanism. You'll need a longer length of 52mm OD tube threaded at 52X1.50 (that corresponds with most 2.25" platforms).
Slip the tube over the damper till it touches the bracketry that holds the hub etc in place. You may need to weld a 'guide bush' in place at the top if there is too much play between the tube and the strut outer. (Most 52mm tube you will find for this purpose has a 46mm ID)
All you then need is to substantially tack the base in place where it touches the hub bracket and avoiding the strut tube. This will be enough to hold everything together..
Hope this helps.
Mike
