cd.thomson
| posted on 27/2/10 at 12:52 PM |
weeping
I have fluid weeping from all over my braking system. Mainly seems to be coming from the top of the fittings through the hole where the brake pipe
passes into the threading fitting rather than from the threads.
Its making a real mess and i have no chance of bleeding the brakes.
solutions?
Anyone want to buy a part built dax rush?
Craig
cd.thomson
| posted on 27/2/10 at 12:56 PM |
wrong ends put on the two main brake lines from the looks of things.
piece of shit.
Craig
twybrow
I'll give you £20 for her, and I'll even wipe the garage floor when I take it away!
Sounds like you need to redo your flared ends. It took me a few attempts to work it out. Plus don't overtighten, as that just makes them leak
even quicker!
cd.thomson
| posted on 27/2/10 at 12:57 PM |
paypal me the money and you can pick it up next week.
Craig
pewe
| posted on 27/2/10 at 01:07 PM |
First rule of building your own car - "One step forward, Two steps back".
Take the rest of the afters off - watch the rugby, footie, womens ice dance - whatever.
HTH.
Cheers, Pewe
twybrow
| posted on 27/2/10 at 01:08 PM |
I might have to insist on cash on collection, don't wanna waste my money after all!
Stick with it mate - it is so worth it the first time you nail the throttle on your first drive. The grin starts to hurt after a while!
A1
| posted on 27/2/10 at 01:55 PM |
yea, stick at it, the grin never leaves. Its so worth it.
ali f27
| posted on 27/2/10 at 02:49 PM |
CHECK YOUR FITTINGS METRIC THREADS ONTO IMP BUT WILL NOT SEAL MIGHT BE THE OTHER WAY ROUND BUT NEED TO GO IN WORKSHOP TO FIND OUT CHEERS
MakeEverything
| posted on 27/2/10 at 03:19 PM |
Take the wekend off, and do something different.
Take a deep breath, remove the brake system clean up any evidence of it happening and start again. Youll feel much more confident in it if you do
start again, rather than repair the existing.
[Edited on 27-22-10 by MakeEverything]
Kindest Regards,
Richard.
Blackbird Rush
| posted on 27/2/10 at 10:20 PM |
piece of shit.
Have you fitted the brake lines the wrong way round?
The std dax supplied kit has metric one end and imperial the other (IIRC the imperial end goes into the master cylinder and the metric end goes into
the caliper flexi hose).
[Edited on 27/2/10 by Blackbird Rush]
