Gary 7
| posted on 4/3/10 at 03:15 PM |
Rear brakes again
I want to fit rear discs and need to reduce the rear braking effort ,currently on drums.I have a wilwood proportioning valve but been told it wont
work because the pressure in the system is to low.
Would a valve from a mondeo fitted to the m/c be suitable . What have others used.
| posted on 4/3/10 at 03:46 PM |
Just stick with drums -- on your they are working well below their stopping capacity.
Rear drums have some advantages over discs in a road car, a much better handbrake, brakes shoes last twice as long as brake pads. and they self-servo
at low pedal pressure.
Gary 7
| posted on 4/3/10 at 04:35 PM |
Brakes are fine as they are its the diff i want to use thats the problem.Tryed to find 25 spline drum braked shafts to fit a lobro on the diff end
,gave up searching.I have bolt on shafts and hubs just need to sort rear discs brakes to go with them.
Ben_Copeland
| posted on 4/3/10 at 06:35 PM |
Perhaps you should of added that in the orginal post, maybe someone could of given advice on that too.
Fitting a valve in the m/c would work, i'm guessing you have single sierra one, instead of twins.
[Edited on 4/3/10 by Ben_Copeland]
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Gary 7
| posted on 4/3/10 at 08:02 PM |
Currently using mk2 escort dual circuit non servo m/c , cortina front calipers,the m/c bore size for the rears is 17mm.
