Author: Subject: weird question about sierra calipers...
blakep82
posted on 9/3/10 at 04:04 PM Reply With Quote
when the brakes wear down, does the slider move towards the middle of the car? the outside of the car? or stay round about where it is?
just had those brackets re-welded, now looking at the sliders, i didn't give them much thought before... now i'm worried they'll not let the pads wear down right
________________________
phelpsa
posted on 9/3/10 at 04:08 PM Reply With Quote
As the piston's on the inside the slider must move inwards to compensate for wear on the outer pad
blakep82
posted on 9/3/10 at 04:10 PM Reply With Quote
ah... i thought as much. will have to take the pads out to check how far it can move then i guess...
thanks
russbost
posted on 9/3/10 at 04:12 PM Reply With Quote
You don't need to take the pads out, just check the thickness of material on the pad - it can't move further than that unless you're planning on going metal to metal on the discs/pads!
blakep82
posted on 9/3/10 at 04:18 PM Reply With Quote
ah yeah, but i don't really know how much movement the sliders got in it to start with
actually i've got one that not on the car, so i can check with that one
[Edited on 9/3/10 by blakep82]
blakep82
posted on 9/3/10 at 04:31 PM Reply With Quote
so when the pads are new the rubber bellows are all squeezed up, and as the wear they expand? is that correct?
so, like this when new pads are in
and this when they're worn?
because this is how they sit now, with new pads in
matt_gsxr
posted on 9/3/10 at 05:00 PM Reply With Quote
yes, that is how they go.
But in the middle of your 3 pictures the piston would be sticking out.
Matt
blakep82
posted on 9/3/10 at 06:11 PM Reply With Quote
Matt
ah, yeah, but it probably wouldn't go that far though eh? as the pads would be down to metal?
