Author: Subject: Cortina mk3 brake cylinder
xico_ze54
posted on 10/3/10 at 11:30 PM Reply With Quote
I'm rebuilding a master cylinder for a Cortina mk3 with servo. it's a first generation of 1972 model.
the cylinder doesn't have mention the bore, but only a reference with many numbers from Girling.
how can I know the bore? or how can I know where to buy a kit to rebuild the master cylinder?
thanks
Chippy
posted on 10/3/10 at 11:44 PM Reply With Quote
Try Big Red they should be able to sort you out. Clicky Cheers Ray
posted on 11/3/10 at 11:06 AM Reply With Quote
It is just a tandem 13/16" (20.6mm) bore Girling tandem cylinder --- If you are using this on your build without a servo would strongly advise using a more suitable cylinder with a smaller bore otherwise you will need excessive pedal pressure to stop the car.
You might want to consider the master cylinder from a a pre 1990 VW Polo without servo. or a pre 1990 Fiat Panda
boggle
posted on 11/3/10 at 11:29 AM Reply With Quote
so a smaller bore helps unassisted brakes?
u2u me for details
posted on 11/3/10 at 11:40 AM Reply With Quote
Pressure = force per unit area
Ergo :
Same force applied a smaller bore piston = higher hydraulic pressure.
xico_ze54
posted on 12/3/10 at 12:52 AM Reply With Quote
the Cortina master cylinder again
here is the number engraved in the Girling master cylinder body (and this is all):
098 646776683 G
if this sounds anything to anybody... please tell me.
thank you
Amadeu
posted on 12/3/10 at 08:40 AM Reply With Quote
Thats just a casting number it is the same for all master cylinders of that general style.
xico_ze54
posted on 12/3/10 at 11:34 AM Reply With Quote
so I have to desassemble it to measure the bore. thats it?
