rsmith95uk
| posted on 11/3/10 at 08:10 PM |
Hydraulic Brake Light Switch
trying to find a cheap M10 switch (and brake line 'T' piece).
Doesn't seem to be any suitable on the bay - I may be wording my search incorrectly - but have found one for £12 on Europa site, is this
reasonable?
Ray
ashg
| posted on 11/3/10 at 08:22 PM |
£6 at cbs
click
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
big_wasa
| posted on 11/3/10 at 08:26 PM |
You want a low presure one from something like an mgb
http://cgi.ebay.co.uk/MGB-Sprite-Midget-Mini-Hydraulic-Brake-Switch-C16062A_W0QQitemZ190375913372QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?
hash=item2c5349e79c
rsmith95uk
posted on 11/3/10 at 08:29 PM |
thanks for the quick replies chaps
austin man
| posted on 11/3/10 at 09:45 PM |
I and another two members have the hydraulic ones and each one of us has had problems in that the lights do not come on until the brakes have nearly
locked up, we have all now fitted alternative switches onto the pedal, make sure you get a really low pressure switch, the amount of coming togethers
weve nearly had wasn't pleasant
iank
| posted on 11/3/10 at 09:53 PM |
one thing to watch is mounting it so you don' t get a bubble between T-piece and switch. A lot of people have them pointing their terminals
upwards which can cause problems with them only coming on when brakes are given a good shove.
There are, at least, two pressure versions high and low. You want low.
Anonymous
Angel Acevedo
| posted on 14/3/10 at 02:42 AM |
Mechanical Brake Switch
Why don´t you use a mechanical Switch?
That way you can push the pedal a couple of mm before you actually have braking pressure.
This means light comes on earlier.
This is not a new idea by any means, this has been discussed before.
MikeR
| posted on 14/3/10 at 09:21 AM |
So how do you identify a low pressure switch?
(i think i've got one and my plan was to mount it at 90 degrees to vertical so i didn't get a bubble)
| posted on 14/3/10 at 10:58 AM |
I have also heard it helps if you put your cds in the freezer overnight, ignoring hydrostatic effects hydraulic pressure is the same at any point
in closed hydraulic system where no fluid is actually flowing.
iank
| posted on 14/3/10 at 11:19 AM |
? Not sure what your point is?
We are talking about switches that switch at different actuation pressures, not looking for the best place in a pipe to put the switch...
Anonymous
RK
| posted on 14/3/10 at 02:31 PM |
I mounted my hydraulic switch right on the master cylinder, as the Tilton system has two possible places for the lines to go. My lights go on right
away, and I've had no problems with the switch (my leak is further down the line).
| posted on 14/3/10 at 02:50 PM |
I think you are well aware of the point I was making.
[Edited on 14/3/10 by britishtrident]
