Author: Subject: Caliper identification
aka Keith
posted on 15/3/10 at 05:18 PM Reply With Quote
Following on from my earlier post about sierra 4x4 calipers, I am now very confused.
linky here
I thought that I had sierra 4x4 back end, but according to the online info I can find, the piston on 4x4 calipers is 43mm, but the piston on mine is only 40mm - -so what calipers do I have, does anyone have any ideas. (solid disk if that helps)
I do not want to replace both , if I do not have too, but I want to sure that I am ordering the correct thing - if I am only ordering one side.
Would much appreaciate your thoughts,
Craig
meany
posted on 15/3/10 at 07:39 PM Reply With Quote
have a compare on brakes international website.
http://www.car-brakes.co.uk/
aka Keith
posted on 15/3/10 at 08:12 PM Reply With Quote
Meany, I have looke and looked at this site, but can only find calipers with pistons of 42.8mm bore.
so where do my 40mm come from?
I assume thatif I have different bore sizes on each side of the car I will have different braking pressures on each side, which is a no no.
So i either need to replace both rear calipers (which I do not want to do) or identify this rear caliper so that I can get it replaced.
