derf
| posted on 3/5/04 at 01:47 PM |
Any one in the US use Camaro spindles?
I dont belive that they really sold the Camaro outside of the US, but has anyone used the front spindles off of a camaro? I can get a dent price on
them locally, but the uppewr part of the spindle is fairly high, will that pose a problem, or should I keep searching for s10/blazer/jimmy/sonoma
spindles?
Here is a photo of the front suspension in full.
Fifer
| posted on 3/5/04 at 02:36 PM |
Errr, Which part of the front end is a "spindle" ??
Just wondered
| posted on 3/5/04 at 02:52 PM |
Chop that stupid top arm off and drill it.
You would almost have a cortina upright if you could get a taper cut in it.
Dale
| posted on 3/5/04 at 02:54 PM |
I think you could use them but you would have to cut the top ball joint mount off way down andput a ball joint adaptor on in similar to the factory
five cobar ones.
S-10 ones seem to work well if you look at the stalker v6
Dale
