antonio
posted on 20/3/10 at 05:44 PM |
check my corner weighting please
any idea welcome!
tried to get more weight on front but was not able
rear is about 58% and cross close to 50% (49.8)
any good?
[Edited on 20/3/10 by antonio]
MakeEverything
posted on 20/3/10 at 06:03 PM |
Is this with you sitting in it?
Corner weights should be set with the driver in situ.
Kindest Regards,
Richard.
stuart_g
posted on 20/3/10 at 06:07 PM |
I would say that is near spot on. I would just get the front wheels the same weight each side.
Here is a picture of my car on the scales at AB performance with me in it.
![](/galpreviews/2P1010221.JPG) ![Description](/gallery/2P1010221.JPG) Description
adithorp
posted on 20/3/10 at 06:13 PM |
It's not possible to alter the front/rear % or the left/right % without physically moving or adding mass. Corner weighting only allows you to
alter the cross weighting.
http://jpsc.org.uk/forum/
posted on 20/3/10 at 06:19 PM |
The weights should be set with drive in seat --- ie normal loaded condition.
Setting the front weights equal is ok for Formula type single seater but not ideal for a sports car.
The front rear weight distribution should be worked out and the left-right distribution then target weights worked out for each wheel.
antonio
posted on 20/3/10 at 06:34 PM |
my weight on driver side (me plus helmet and everything else) when did it and 25 liters of fuel on tank
posted on 20/3/10 at 06:59 PM |
Did the sums you are close to ideal
LF 118.5 RF 124.5
LR 162.5 RR 170.5
antonio
posted on 20/3/10 at 07:11 PM |
LF 118.5 RF 124.5
LR 162.5 RR 170.5
great!
many thanks!i'll try to corect it tomorow
