phoenix70
| posted on 23/3/10 at 09:11 AM |
Steering column play
I seem to have a lot of play in my steering column, it seems to be around the top of the column where it attaches to the car (MK Indy, Sierra
Column).
I notice on the underside of the column mount there seems to be a couple of hole that look like a pinch bolt should be in there, mines
doesn't.
Anyway as I've got to get an MOT soon, I think I need to sort out this movement.
Scott
Bumble
| posted on 23/3/10 at 09:25 AM |
I had a similar problem and changed the plastic / rubber ford bush through the bulk head to a proper bearing as per the advice received on here.
Solid as a rock now and very easy to do.
Link to previous thread below.
HTH,
Matt
LINK
phoenix70
| posted on 23/3/10 at 09:38 AM |
Thanks for the reply, I think I'll make that changes, never did like the plastic 'bearing' that FORD uses. The play seems to be
more at the top of the column (at the steering wheel).
Regards
Scott
eznfrank
| posted on 23/3/10 at 09:40 AM |
Apologies if this is answered in the other thread but I have a pinch bolt in mine.
