Author: Subject: Brake Fluid Hose 4mm - Res to M/C
whitestu
posted on 25/3/10 at 08:30 AM Reply With Quote
Anyone know where I can get some 4mm id fluid resistant hose to go to my Fiat m/c?
The barbs going into the m/c are too narrow to seal with the standard 6mm stuff, and I can't find 4mm anywhere.
I'm currently using some 4mm rubber breather pipe but it is seeping fluid through the walls.
Stu
iank
posted on 25/3/10 at 08:35 AM Reply With Quote
What about using Fiat hoses. See the post from wicket in this thread for part numbers.
http://www.locostbuilders.co.uk/viewthread.php?tid=69243
Anonymous
whitestu
posted on 25/3/10 at 08:38 AM Reply With Quote
Is that 4mm though?
Stu
iank
posted on 25/3/10 at 08:55 AM Reply With Quote
Assumed it must be as it's for the smallest Fiat made, but I don't know for sure.
Which Fiat is the master cylinder from?
Anonymous
whitestu
posted on 25/3/10 at 08:57 AM Reply With Quote
Mine's from a 1970's Fiat 124.
whitestu
posted on 25/3/10 at 10:28 AM Reply With Quote
I think I've found some suitable hose on ebay so will give that a go.
Stu
