blakep82
| posted on 1/4/10 at 02:22 PM |
3rd time lucky?
________________________
| posted on 1/4/10 at 02:24 PM |
Looks canny, what did you use to get the rust off and what you using to stop it coming back?
Got two to do myself
blakep82
| posted on 1/4/10 at 02:29 PM |
crossed fingers
all the brackets, tubes etc are all new (well, 2 or 3 years ago maybe, but have been painted)
thats the 3rd time o've sprayed it now, so the diff casing was 'ok' for rush, had a go with nitromors, a wire brush, and de greased
it, then sprayed with a thin layer of etch primer first, then some zinc primer (i know it should be on the metal, but the etc was more important i
thougt) then sprayed several coats of everything.
after the third time of painting it, i decided if it comes off again, it comes off... spent far too long on this bit.
iank
| posted on 1/4/10 at 02:43 PM |
Do the welds look better this time?
(think they do, but it's hard to see)
Anonymous
blakep82
| posted on 1/4/10 at 02:50 PM |
yeah, got them redone by a welding place i found at the industrial estate. he re did the brake welds and i asked him to check over the rest. he said
the others looked fine
[Edited on 1/4/10 by blakep82]
| posted on 1/4/10 at 02:53 PM |
You'll be getting the hang of it now Blake
blakep82
| posted on 1/4/10 at 02:55 PM |
got enough practise got impatient with it yesterday, blowing a gale outside, but i did it anyway, sprayed on too thick and it started to run, but
in the words of Einstein, "F**k it"
i assume he said it at some point...
past caring what it looks like now, just want all the gears put back in so it works
iank
| posted on 1/4/10 at 02:57 PM |
In my non-expert opinion those look fine now.
Anonymous
