Author: Subject: Steering rack mounts
prawnabie
posted on 9/4/10 at 12:11 PM Reply With Quote
Hi guys
Ive just had my 2.4 rack delivered from rally design with a pair of alloy mounts.
The mounts have to random offcuts of plastic with them, one thicker than the other. I assume the rack sits on these whilst the mount obv. goes over the top.
Do I have this correct as they are both and a few mm bigger than the mounts - I assume they need to be trimmed to fit?
Shaun
big-vee-twin
posted on 9/4/10 at 12:15 PM Reply With Quote
The plastic bits go under the rack and between the brackets, I had to trim mine a little as they were too big.
http://www.triangleltd.com
blakep82
posted on 9/4/10 at 01:07 PM Reply With Quote
i never got any with mine (2nd hand, and not from RD)
is it just plastic? or more like rubber? my rack does jiggle side to side ( ) a bit when i move the steering wheel
________________________
prawnabie
posted on 9/4/10 at 01:55 PM Reply With Quote
Thanks for the replies!
Its more like a perspex square, but the one for the small mount is thicker than the other.
boggle
posted on 9/4/10 at 02:11 PM Reply With Quote
i made mine to suit the oe rubbers, but im told you get a better feel without them....
u2u me for details
blakep82
posted on 9/4/10 at 03:51 PM Reply With Quote
wouldn't perspex just shatter when tightened up? weird. looks like rubber on the rally design site. might try some from rubber, see how that works
big_wasa
posted on 9/4/10 at 05:15 PM Reply With Quote
Ive also gota pair without.
Just using a square of stiff ruber.
posted on 9/4/10 at 08:34 PM Reply With Quote
I also had to make up a shim to fit inside the larger of the 2 clamps as the rack rotated inside the clamps easily , made it out of a plastic ice cream tub .
PuppiesBalls
posted on 12/4/10 at 03:47 PM Reply With Quote
Any pics of the rack mounts guys? Id like to replace my dodgy rubber bit
prawnabie
posted on 12/4/10 at 05:53 PM Reply With Quote
Ive got 2 poly mounts for sale for a tenner inc post if anyones interested?
