alan wheeldon
| posted on 8/5/04 at 04:03 PM |
wheels
which ford wheels can i use on sierra hubs??
phelpsa
| posted on 8/5/04 at 04:05 PM |
Any ford, peugeot, citroen 4 stud wheels, or any with 108mmx4 pcd.
Adam
alan wheeldon
| posted on 8/5/04 at 04:11 PM |
thanks, ill get the focus ones that i have seen then
mackie
| posted on 8/5/04 at 06:00 PM |
Just bare in mind that offsets will vary quite a lot from model to model even if the PCD is the same. Not sure how focus compares to sierra but
i'd imagine it would have a bigger negative offset.
| posted on 8/5/04 at 06:05 PM |
Don't think Focus wheels fit -- I THINK got to be from an older generation Ford
The RWD Escort and Capri had wheel offsets that gave a wider track configuration.
The offset on the Sierra is similar to the frtont drive Escort and Fiesta.
flak monkey
| posted on 8/5/04 at 06:10 PM |
I saw a 7 type with Focus LX wheels on at Stoneleigh...it looked very much like a GTS to me...anyone else see it?
If the focus wheels wont fit sierra hubs what was he using?
I think phelpsa is right, all fords have the same PCD, just different offsets...
Sera
http://www.motosera.com
phelpsa
| posted on 8/5/04 at 07:58 PM |
Some, and note some, focus wheels have a 52.2mm offset. The sierra is about 38mm I think.
Adam
| posted on 8/5/04 at 07:59 PM |
The Focus wheels definately do fit - though they do have a 3mm offset difference from the standard Sierra. As seen on MK's website.
Jon Ison
| posted on 8/5/04 at 08:25 PM |
the isonblade ran focus wheels with no problems...........
