keith777
| posted on 11/4/10 at 02:22 PM |
tyre pressure
I'm running 205/17/40s on my indy,checked tyre pressures yesterday although they were all between 10/10.5 I thought that was a bit low. cheers
guys Keith
bi22le
| posted on 11/4/10 at 03:02 PM |
IIRC the common thoughts are about 18psi all round. Thats what most people run and thats what I run. 10psi seems very low!
HTH
Please read my ring story:
keith777
| posted on 11/4/10 at 03:43 PM |
Many thanks
| posted on 11/4/10 at 04:04 PM |
Got 14psi in mine but thinking of raising that a bit.. the backs squirm when cornering hard
DRC INDY 7
| posted on 11/4/10 at 06:44 PM |
18 psi all round
Puddle Dodgers Club
Angel Acevedo
| posted on 12/4/10 at 06:29 AM |
Tire pressure test
On a dry road, mark wth chalk or crayon 4 to 6 lines on the treads spanning across each tire, push the car enough to do a couple of revs, then check
how the lines vanish.
If the center of the lines wear first, then it is too much, if the sides, then too low.
Adjust pressure a couple of psi as required, then retest.
Repeat until you are satisfied with "wear" pattern.
this test may point to camber issues too.
