timf
posted on 11/5/04 at 08:19 AM |
seals
any one know if it is possible to get the dust seals for cortina uprights on there own or is it the case for the wheel bearing kits.
Tim
ned
posted on 11/5/04 at 08:31 AM |
Tim,
By dust covers I assume you mean the round cap that goes over the end of the hub nut?
This wasn't included in the wheel bearing kit I bought, so presume it should be able to be bought separately.
Ned.
beware, I've got yellow skin
timf
posted on 11/5/04 at 08:34 AM |
no i mean the dust seal at the rear
that stops all the grease being lost/contaminated looks like a big oil seal
ned
posted on 11/5/04 at 09:20 AM |
ahhh, that bit came with the wheel bearing kit, sorry!
Ned.
andyps
posted on 16/5/04 at 02:50 PM |
If it is an oil seal, you will be able to buy one easily from any bearing distributor. Just take an old one or accurate dimensions with you and they
should be able to sort one out. Look in Yellow Pages under Bearing Stockists.
Tblue
posted on 16/5/04 at 04:15 PM |
andyps is not a million miles off, it is a standard size and will be available from any good bearing factors. I got mine from Huddersfield Bearings
from stock (can't remember the sizes though), all you need is an old seal or tell them the o.d. and i.d. and they'll get you one (two?) no
problem.
Also for your info, the outer steel caps are available from Rally Design.
Mark Allanson
posted on 16/5/04 at 08:36 PM |
Also available at any ford dealer at £1.29 each
Tblue
posted on 16/5/04 at 09:02 PM |
Which is slightly cheaper than Raldes as theirs are £3.90 +vat.
