bigfoot4616
| posted on 25/4/10 at 10:15 AM |
stepped washers?
my accelerator pedal is fixed to a bar that runs in one of these each end
one has fallen in bits.
any one know where i can get some from, found some on ebay but they're to small.
not even sure what the correct term is for them
cheers
| posted on 25/4/10 at 10:21 AM |
Pedal bush, is it fibre or plastic? Standard Ford fitment if it is the same as my old Striker.
tomgregory2000
top hat washer?
Davegtst
| posted on 25/4/10 at 10:22 AM |
Renault Clio's use plastic ones on the clutch pedals. Not sure if they are the right size though.
bigfoot4616
| posted on 25/4/10 at 11:13 AM |
its plastic.
ford fitment sounds hopefull, need it sorted for croft next monday.
important dimensions are center bore 9.7mm and the hole it sits in is 13.8mm
bigfoot4616
| posted on 26/4/10 at 04:18 PM |
found some in the scrappy that will do for now with a bit of fettling until i get the right ones
