dave r
| posted on 30/4/10 at 04:26 PM |
sierra rack not long enough
a sierra non power assisted rack
my problem is, the rod ends are not long enough , but too long to put rod extenders like a lot of the kit car manufacturers supply
i need about another 15mm length each end, as the outs rod ends are only screwed on by about 3 turns!
anyone know if any other fords are the same ball size yet longer, and still m14??
Lars
| posted on 30/4/10 at 04:29 PM |
could you use a female rose joint?
And then just put a bolt through?
no sure if they are longer or shorter though (possible shorter, but then enable you to fit rack extensions)
Dusty
| posted on 30/4/10 at 04:32 PM |
I'm currently looking at the same problem and think I will have to shorten the track rods to get the extensions on.
snapper
| posted on 30/4/10 at 04:41 PM |
Article in Complete Kit Car had the same problem with the riot, they cut the track rod end back and the threaded part of the rack back.
I eat to survive
I drink to forget
| posted on 30/4/10 at 04:47 PM |
Is it a standard Sierra rack? Won't you have bump steer if it's not cut down? I'm not sure I completely understand the
problem.............
Phil
| posted on 30/4/10 at 06:37 PM |
I take it the Sierra track rods unlike those the Escort rack don't have rolled threads.
The track rods on Escort Mk2 (and Cortina 3-5) rack have rolled threads so the actual track rod diameter is smaller than M14 so cutting an M14
thread with tap isn't safe.
| posted on 30/4/10 at 06:39 PM |
Phil
Yeah narrowing the centre section would be the way to go.
[Edited on 30/4/10 by britishtrident]
dave r
| posted on 30/4/10 at 09:13 PM |
no it wouldnt as its not on a locost
i have very little bumpsteer
dave r
| posted on 1/5/10 at 07:53 AM |
someone has told me that granada rod ends have the same taper but are longer
can anyone confirm ?
