John P
| posted on 3/5/10 at 08:10 AM |
Where is the Track measured between?
When talking about the track of a car where is this measured between? Is it the face the wheel bolts up against?
John.
Mal
| posted on 3/5/10 at 08:21 AM |
I think it is the distance between the centres of the tyre treads, but I stand to be corrected.
Mal
designer
| posted on 3/5/10 at 08:23 AM |
Yes, middle of tyre to middle of tyre on same axle.
| posted on 3/5/10 at 08:33 AM |
Centre line of tyres but I have never seen this defined in an authoritative source such a an SAE standard.
Humbug
| posted on 3/5/10 at 09:29 AM |
so track depends on tyre width and wheel offset as well as hub to hub distance?
John P
| posted on 3/5/10 at 09:30 AM |
That's interesting because it means the track will be less than the width across the mounting flanges.
dhutch
| posted on 3/5/10 at 09:51 AM |
Which, for the sake of measure is of cause the same as from one edge to the other.
