mutleylocost
| posted on 4/5/10 at 05:55 PM |
Male threaded track rod ends
Anyone know of a track rod end with a male thread (if poss. m14 x 2 same as rack) that will fit into cortina hub / steering arm.
Need to extend drumsticks and want to use a bit of aluminium hexagonal bar with a thread thru it
Ben_Copeland
| posted on 4/5/10 at 06:20 PM |
Wouldnt it just be easier to do it the normal way???
Whereabouts in Kent are you ?
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
mutleylocost
| posted on 4/5/10 at 06:23 PM |
Hi, only need to extend by about 60mm and thought it may be an easier option.
Am in Maidstone.
blakep82
| posted on 4/5/10 at 07:28 PM |
m14 male rose joints can be used. not sure what work needs done on the upright though... think they need the taper drilled out or something, and a
14mm high tensile bolt put though with big thick wshers either side of the rose joint
________________________
| posted on 5/5/10 at 06:08 PM |
The taper Ford used is pretty uncommon on track rod ends I am pretty sure no male M14x2 TRE exists with the same taper otherwise somebody would have
used it and shared the info.
