MikeR
posted on 17/5/04 at 07:20 AM |
Starter Motors - ARRRGGGHHHHH
Do you want to know how pissed off I am ...... 4 years, 4 fecking years I've been building my car and at 7pm yesterday I discover my starter
motor won't engage with my fecking flywheel!
So, what starter motor do I need to turn a caterham lightened supersprint flywheel - and where the fecking hell can i get one (at a locost price)
feck
even had a full jury rigged cooling system
even cleaned the 1/2 inch bits of metal and bolt out of the sump! (Don't ask I'm ignoring that bit)
even made two temporary gaskets out of an old frozen pizza box
feck
James
posted on 17/5/04 at 08:52 AM |
Can't help you with the starter- but good luck sorting it out!
Mine's been over 2 years now and I know how you feel! Thought I'd be ready to fire up the engine myself this weekend- now I've
discovered new carb won't fit the inlet manifold!
Aaaaaagh!
Atb,
James
MikeR
posted on 17/5/04 at 11:56 AM |
and now my life is complete - i've even posted this in the wrong section!!!!!
MikeR
posted on 17/5/04 at 12:03 PM |
Twice...
James
posted on 17/5/04 at 02:38 PM |
Lol!
posted on 17/5/04 at 02:52 PM |
What carb is it James?
If it's the 32/36 Weber off the Cortina just oval the boltholes with a round file. We did one and it worked o.k.
posted on 17/5/04 at 03:18 PM |
Breath in and count to 10... that's what we had to do before removing our engine again to replace the frigging gearbox...
It's all in the grand scheme of things - and besides what would life be like without tinkering eh?
Oh and not much consolation but 2/3 of our team only did 180 collective miles from about 600!!! But so what.... here we go again!
MikeR
posted on 17/5/04 at 04:30 PM |
Arrgghhhhahhhthhhahhthththt
yeah but where the heck am I going to get a sodding starter from
i know could to ten, count to ten.....
leaving the garage alone for a couple of days before i face the devistation from the weekend (its a bit messy at the moment)
Dale
posted on 17/5/04 at 05:51 PM |
Is there the possiblilty of purchasing a rebuild kit for the apropriate starter that caterham uses and just use the gear from it (if it fits the
shaft).
That would likely require more luck than I have to get a shaft size match.
Dale
Dave Ashurst
posted on 17/5/04 at 07:28 PM |
I've got a spare flywheel if it's any help.
Dave
MikeR
posted on 17/5/04 at 07:54 PM |
don't need a flywheel, got a spare already ........ hmmm, actually, dave whats the ring gear on your flywheel ?
givemethebighammer
posted on 17/5/04 at 08:01 PM |
I'm sure the caterham starter is some sort of Ford Crossflow unit. Perhaps you should take a jumpover to blatchat or the westfield forum
http://www.blatchat.com/
http://boardroom.wscc.co.uk/cgi-bin/ikonboard.cgi
both useful for information, however people can be slightly more serious than on this forum.
Deckman001
posted on 17/5/04 at 08:24 PM |
Aren't there two types of starter, pre-engaged and inertia type for x/flows try the other type to the one you have, if you could get to the ring
gear, you would be able to see if the teeth have a slight bevel at the front of them for the inertia type, and straight edged gears for the
pre-engaged
Jason
MikeR
posted on 17/5/04 at 08:44 PM |
Interesting, I thought that their where two types of ring gear, straight and helical. I'm pretty sure I've got straight teeth on the ring
gear.
I've got two starters, one with a big solonoid on its back and one with a spring on the shaft. I know the one with the spring on the shaft has
slightly mashed teeth which are bevelled. The solonoid one - i haven't a clue it went from one car to another in about 30 seconds without
looking at it.
Tomorrow night I'll take them both into the garden, give them a damned good thrashing and then have a look at them
[Edited on 17/5/04 by MikeR]
paulf
posted on 17/5/04 at 08:57 PM |
Mike I had a problem with my starter motor, the engine came fitted with a FWD starter motor which would not fit the type 9 bell housing.I fitted a
Sierra motor but then found it would not turn the engine correctly as it jammed in mesh with the flywheel as the pinion throw was the wrong length.
I then tried an inertia starter which turned the engine but made a horrendous noise.
Further investigation found i had a ring gear for a pre engaged starter which does not match the inertia type.
I eventually made three spacers to space the sierra motor away from the block by about 8mm and it now works smoothly.
I would therefore check the reason for not meshing to ensure the length from the pinion to ring gear is correct.
Paul.
looking at it.
Dave Ashurst
posted on 17/5/04 at 10:20 PM |
Inertia type.
derf
posted on 17/5/04 at 10:51 PM |
You could always rig up a hand crank system....
MikeR
posted on 17/5/04 at 10:56 PM |
Dave - I'll be in touch.
We did consider the hand crank system, but my partner in crime (who's fault the whole 7 hour "lets get your engine started"
experience was) didn't think he could crank the engine using my rachet more than 10 to 15 rpm. A fair way short of the few hundred rpm i need
to get ignition!
givemethebighammer
posted on 18/5/04 at 09:47 AM |
found this any good ?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=9903&item=2478443538&rd=1
MikeR
posted on 18/5/04 at 11:14 AM |
found it last night and I'm watching it.
The interesting thing is - it looks identical to the second starter I've got that I tried to hurridly fit at 7pm. Going to have another look at
it tonight to make sure i did fit it properly. If that doesn't work I'll then bid on the ebay starter.
one day she may start ...... one day
posted on 18/5/04 at 11:47 AM |
to get ignition!
If the engine's in reasonable condition and willing to start, then you only need 1/4 to 1/3 of one revolution to start on a handle.
For example, in the past I've hand-cranked into life a 2.6 litre straight-six Rover 100 (P4) engine - no problem (as long as you keep your thumb
on the correct side of the handle, in case of backfire). It's a technique, that's all.
posted on 18/5/04 at 12:17 PM |
Can't you bump start it? or isn't that an option. A spot of petrol down the carb should give you a start. I wonder if a 12v impact driver
on the crank pulley would turn it over or a big drill with a socket attached.
MikeR
posted on 18/5/04 at 03:05 PM |
bump start .... hmm, that might require a prop
hmmm, the idea of cranking it is interesting. Do you think I could get away with using a ratchet?
stephen_gusterson
posted on 18/5/04 at 03:40 PM |
Only if you plan on not needing most of your fingers, and poss an arm for the rest of your life.....
atb
steve
