cd.thomson
| posted on 16/5/10 at 08:09 AM |
brake feel/bleeding
Morning guys,
car is now "finished" ready for IVA this week. The only thing I'm currently not happy with is the brake feel. I've never had
non-servoed brakes so I'll describe what I mean to see if its an issue:
Basically I would expect the pedal to be pretty firm from the top of the stroke, but there is a certain amount of travel which is "soft"
(about 1.5 inches). It then takes another .5 of an inch before the brake lights illuminate. There is still loads of firm travel left in there after
this, and I can lock the brakes easily.
I suspect this means there may be air somewhere but I bled the brakes as advised from previous posts on here: furthest to nearest, through a hose into
a pot of fluid and twice round until the fluid ran out of the caliper smooth. Could there be air trapped somewhere still? What can I do about it?
Also I'm running a bias bar setup, could I have set this up incorrectly, so its "loose" or something?
[Edited on 16/5/10 by cd.thomson]
Craig
madteg
| posted on 16/5/10 at 08:12 AM |
Sounds like brakes want bedding in to me
cd.thomson
| posted on 16/5/10 at 08:15 AM |
i hope so! because i can start getting them run in on the way over to the test
Craig
RazMan
| posted on 16/5/10 at 08:51 AM |
Yep, new pads can take a hundred miles or more to properly bed in. I remember having the same reservations when I finished my car - a few days of
driving sorted them out.
Raz
cd.thomson
| posted on 16/5/10 at 08:58 AM |
cheers guys
i was confused as it didnt really feel "spongey" and there was no pumping up/pedal creep symptoms
Craig
| posted on 16/5/10 at 10:46 AM |
The other thing that could cause this is an air bubble under the brake light switch (depending on how you have it mounted)....
| posted on 17/5/10 at 12:29 PM |
If you have alloy calipers they probably aren't 100% true to the disc, bedding in the pads will reduce BUT won't cure it completely.
