Lars
| posted on 16/5/10 at 08:50 PM |
What's broken?
finally got round to mapping my car, but have found a couple of issues
THe main one is that there apears to be a clicking/"loose bolt in a metal box" type noise on the rear near side
It does not happen all the time but appears particularly pertinent when cornering (right hand bends) and can also happen on uneven roads.
I checked the rear for obvious problems but could not spot anything.
Will investigate further over the next few days, but thought I would ask if anyone else has had this problem.
I am driving a dedion rear with a lsd slipper and drum brakes (both sierra), with custom shafts
Anyone know what might cause this
tomprescott
| posted on 16/5/10 at 09:29 PM |
Bearing?
A bird in the hand....
Lars
| posted on 16/5/10 at 09:41 PM |
you mean wheel bearing?
it will probably be one of the first things to change, as it it one of the easier things to change
unless of course someone can tell me what else it may be
anyone one know if it is likely to be caused by the diff?
Bluemoon
| posted on 16/5/10 at 09:44 PM |
I guess this is a new noise? Or have you only just got on the road? I do get plenty of odd transmission noises, not quite lose nut in a box
though!
Dan
Pete Jordan
| posted on 16/5/10 at 09:48 PM |
Sounds like a wheel bearing starting to break up to me.
Lars
| posted on 16/5/10 at 09:49 PM |
it is just back on the road following the dedion conversion
donor bits from scrap yard, so unknown condition.
Chippy
| posted on 16/5/10 at 10:41 PM |
Wheel bearing usually rumble when on the way out, I have never heard of one that sounded like a "loose bolt in a metal box". Easy way to
check is jack up the car and spin the wheel, if it's a nackered bearing you will soon hear it. HTH Cheers Ray
MkIndy7
| posted on 16/5/10 at 10:56 PM |
Have a look and check its not the alternator fan catching on the chassis and that all the engine mountings are tight.
Lars
| posted on 16/5/10 at 11:33 PM |
might change the rear bearing anyway, cheap and straight forward
Chippy - I will try that but not sure if that will tell me anymore as I can even drive along on a the flat an will hear no noise.
It seems mostly on hard cornering (right hand bends)
MKIndy7 - noise is definitely from behind me not the enginebay
Lars
| posted on 16/5/10 at 11:34 PM |
I am just really hoping it's not the diff
That would mean a lot more time and money
jollygreengiant
| posted on 17/5/10 at 08:34 AM |
If you've got bolt on shaft to the diff, I would suggest a CV joint.
Lars
| posted on 17/5/10 at 10:23 AM |
yes it is bolt on, but the cv joint is brand new.
It is cheap enough to replace, so will try it. However wheel bearing is second hand so will probably try that first.
MakeEverything
| posted on 17/5/10 at 10:35 AM |
Checkall the drum springs and shoes. I had this on my c class (never buy a mercedes) and it was the brake springs inside the drum rubbing on the
wheel bolts. Every revolution there was a loud "Ping". Eventually it went TWANG, as the spring broke, just before i got to the garage.
Kindest Regards,
Richard.
MkIndy7
| posted on 17/5/10 at 01:02 PM |
I would have sworn blind my noise was coming from the back.. but it was the alternator on the chassis after the engine mounts had come a little loose
so don't rule it out without having a quick look.
Lars
| posted on 17/5/10 at 09:35 PM |
thanks guys, will check drums and engine bay
matt has agreed to help me changing the wheel bearing so will do that at the weekend too.
i shall let you guys know once i find out what it was
norfolkluego
| posted on 18/5/10 at 10:10 PM |
We've picked up a bit of grit in the alternator (sprinting on airfields !) sounds exactly as you describe, my remedy is - hoping it drops out!
