nige
posted on 18/5/04 at 01:22 PM |
bottom steering joint ?
done a search not found the answer
can anyone tell us if you can still use
the cush drive coupler at the rack end
or does it have to be a steel u/j
if so where can i get them
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
stephen_gusterson
posted on 18/5/04 at 01:23 PM |
why sholdnt you be able to use the rubber joint, like 3 million or so sierras did
atb
steve
DavidM
posted on 18/5/04 at 07:13 PM |
I used the rubber joint. Just need to take care that you don't set fire to it when you extend the shaft.
nige
posted on 18/5/04 at 10:22 PM |
have you been through sva with it ?
NS Dev
posted on 19/5/04 at 05:22 PM |
Is the angle that the rubber works at similar to the Sierra (or other donor)??
If it is then there is no problem, but the steering will obviously be slightly "rubbery"!!
If you want to avoid this, you can use a group 4 Ford Escort mk2 coupling UJ, which is a solid UJ with no rubber, available new from many places,
(e.g. Rally Design, part number RD820, price £14.80 Plus VAT)
nige
posted on 19/5/04 at 08:07 PM |
ns dev .... thanks for that
that was the answer i was looking for
cheers mate!!!!!
