Author: Subject: Long shank rod ends
jimgiblett
posted on 26/5/10 at 08:19 PM Reply With Quote
Long shank rod ends
Does anyone know where I can get hold of a 1/2" UNF MALE RH thread rod end with a longer than normal shank/thread.
linky
Dimension A needs to be roughly 3.25" they are normally just under 2.5"
Jim
adithorp
posted on 26/5/10 at 08:30 PM Reply With Quote
Looked a couple of weeks ago and couldn't find any.
adrian
http://jpsc.org.uk/forum/
jimgiblett
posted on 26/5/10 at 08:44 PM Reply With Quote
I want to swap the rear upright top bush on my Fury for a rose joint. I could possibly use a female joint and some UNF studding but that seems a bodge. The other alternative is to remanufacture/modify the top wishbone which seems a lot of hassle and not something I want to start on 3 weeks before we go on tour.
hmmmm......
- Jim
adithorp
posted on 26/5/10 at 08:59 PM Reply With Quote
Guess why I was looking for them.
adrian
jimgiblett
posted on 26/5/10 at 09:05 PM Reply With Quote
adithorp
posted on 26/5/10 at 09:57 PM Reply With Quote
I'm currently thinking along the "If it's not broken, don't fix it" line. Done 5000miles like it is. A thread should be in a min of 1 1/2 times it's diameter and it's further in than that... just!
I'm thinking of maybe adding a second lock nut and short tube between the nuts just to stiffen it up where the exposed thread is.
adrian
jimgiblett
posted on 26/5/10 at 10:05 PM Reply With Quote
adrian
That sounds sensible. I may copy. I just wanted it fully adjustable for when it goes in for laser alignment/cornerweighting. But I am running out of time.
- Jim
carpmart
posted on 27/5/10 at 06:13 AM Reply With Quote
I had a similar issue on my race car and had a spacer machined.
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
Nick Skidmore
posted on 28/5/10 at 08:00 AM Reply With Quote
There are some extended shank rod ends available.
They are 1/2 unf shank with a 3/8 bore available RH and LH. Not Mcgill cheap but they are proper quality.
Contact me if interested
jimgiblett
posted on 28/5/10 at 12:07 PM Reply With Quote
Nick
Unfortunately the retaining/pivot bolt is 1/2" UNF so 3/8" is a non goer.
Thanks though
- Jim
