Author: Subject: steering column help
steve8274
posted on 27/5/10 at 03:56 PM Reply With Quote
hi all
i have an adjustable steering column (didnt realise this until i went to fit it)
trying to fit it to car, but it appears that it is too short. about 9 or 10"
has anyone else had this problem and how do you sort it
any help appreciated
thanks
steve
40inches
posted on 27/5/10 at 05:55 PM Reply With Quote
What do you mean by short? if it is at the triangular end, it may have been pushed into the column, clamp the triangular section in a vice and pull it out of the column till it hits the stop.
steve8274
posted on 28/5/10 at 09:59 AM Reply With Quote
hi
it is the triangular bit which is too short. (not long enough to reach uj and shaft which goes on rack.
i have pulled the triangular bit out a bit further but the only effect it has is to move steering wheel closer to rear of car since on end of triangle bit is white plastic bush?. this is then hitting the rubber and plastic bearing which keeps column in line.
hope you can undertsand what i mean.
thanks
steve
40inches
posted on 28/5/10 at 11:48 AM Reply With Quote
Ah! You have to lengthen the rack to column with a length of tube.
If it helps, the rack to triangular extension on my MK is 32"(81cm)
[Edited on 28-5-10 by 40inches]
