chunky2772
| posted on 2/6/10 at 09:03 PM |
piping up brakes front and rear?
please help! does anyone have any pictures on how the front and rear brakes are piped up! my build is a chris gibbs locost im using ford sierra front
and mazda mx5 rear (discs all round)with two seperate marster cylynders and bias bar. do you use a t piece on the copper brake pipe to split the brake
lines? also does this t piece plit near the marster cylinder or nearest the brake callipers. please help as all of the mechanics im asking havent got
a clue with this being a kit car build.
l0rd
| posted on 2/6/10 at 09:31 PM |
And what are your master cylinders?
daviep
| posted on 2/6/10 at 09:54 PM |
Dual master cylinders - If they are different sizes then smallest usually goes to the front.
The t-pieces can be located anywhere which is convienient for you.
Remember to run your pipes so that they are easy to secure to the chassis.
Davie
big-vee-twin
| posted on 2/6/10 at 10:51 PM |
Hi you can see the tee to split mounted on the bottom rail the one in the vertical pipe feeding the rear is to mount the hydraulic brake switch
The rear split at the back I have a De Dion but the principle is the same and then finishes in brackets then changes to flexis.
[Edited on 2/6/10 by big-vee-twin]
http://www.triangleltd.com
| posted on 3/6/10 at 10:01 AM |
BVT that unsupported front brake pipe crossing an open gap is not a good idea, a friend was failed for similar at a pre-SVA MOT years ago.
matt_gsxr
| posted on 3/6/10 at 10:40 AM |
and the lack of steering feel might be a problem too
chunky2772
| posted on 3/6/10 at 07:22 PM |
brakes
Thanks! that helps me alot the cylinders im using are girling 6.25 front and 7.0 rear. i now understand about not securing the pipework to the chassis
as well it helps to see how other people have fitted there cars out! if anyones got anymore pics or info please post as i would like to get this right
first time round. thanks for the replys so far from mick!
