Author: Subject: master cylinders
beaver34
posted on 3/6/10 at 11:22 PM Reply With Quote
master cylinders
can someone explain the sizes of m/c to me,
what the differnce between 0.625 and 0.70
not just 0.075
Madinventions
posted on 4/6/10 at 12:14 AM Reply With Quote
It's all about the volume of fluid you are moving. A 0.7" diameter master cylinder will move more fluid for a given travel as opposed to a 0.625" one. So basically, a larger diameter master cylinder will give you shorter brake pedal travel and you'd have to press it harder.
A 0.7" diameter m/c will move 7.8cc of fluid per cm of travel, whereas a 0.625" one would move 6.2cc. You therefore need to match the m/c size to the type of calipers you're using (how much piston area) and your preferred feel of brake pedal.
And then of course there's the brake pedal ratio to consider....
Take a look here for some more info.
HTH,
Ed.
[Edited on 4/6/10 by Madinventions]
View my band website:
http://www.shadowlight.org.uk
beaver34
posted on 4/6/10 at 07:44 AM Reply With Quote
HTH,
Ed.
thanks ed,
its for a hydro handbrake, what size should i go for? so if i go for the biggest and wont have to pull it as hard?
JF
posted on 4/6/10 at 07:51 AM Reply With Quote
No if you take the biggest you'll have to pull the hardest, but only a small distance. Take a small one and you'll have to pull the lever further, but with less force.
As mentioned above though, keep into account the lever ratio. And in theory, if you go to small you might not move enough oil to engage the brakes properly.
beaver34
posted on 4/6/10 at 08:08 AM Reply With Quote
ahh, i see there is alot of lever travel,
what do you think i should use, i run cosworth rear calipers
PuppiesBalls
posted on 4/6/10 at 08:34 AM Reply With Quote
is it possible to use a notmal master cylinder for a hydraulic handbreak?
