Lightning
posted on 6/6/10 at 08:08 PM |
Front brakes binding
What am I doing wrong? The brakes are free but after some 15 miles the front bind. I have taken out the pistons and polished them. The carrage has
been cleaned and copper grease on the moving parts.
Is it that I have synthetic 5.1 fluid?
CRAIGR
| posted on 6/6/10 at 08:14 PM |
Make sure the brake pedal is returning fully and not pushing slightly on the master cylinder. Had this on my Fury and replaced calipers m/cyl etc then
found it only needed a small spring to return pedal fully to cure it. doh!!!
P.s Loving the Spire
[Edited on 6/6/10 by CRAIGR]
adithorp
Have you got play in your master cylinder push rod when your foot is off the brake?
If not you'll get binding brakes.
adrian
http://jpsc.org.uk/forum/
| posted on 6/6/10 at 08:15 PM |
Almost certainly the age old favourite of the master cylinder not fully returning. This blocks off the return port, so as the fluid in the brake
calipers warms up it expands and pushes the piston out instead of returning to the reservoir.
EDIT: I need to type faster
[Edited on 6/6/10 by MikeRJ]
Lightning
| posted on 6/6/10 at 08:39 PM |
Hope its that,should be any easy fix. Thanks guys
